Worked on the water spout. I found some gray PVC 1 1/4 OD x 1" ID pipe, with a flared end that should work just right. At this scale it works out to be 10" across, about the right size of the prototype. Tried to heat and bend the snout end, and failed miserably! Thought to cut out some wedges and bend on itself… Yuckkk cutting the wedges the right shape and location proved to be my undoing… decided to cut wedges and cement the wedges back together to form the spout. Set a cut angle of about 7 deg. on the band saw, and cut the first piece.
(http://i1234.photobucket.com/albums/ff403/dave2-8-0/WT-109.jpg)
Then rolled the pipe 180 deg. and cut again to make the wedge. Repeat until you have more then you need.
(http://i1234.photobucket.com/albums/ff403/dave2-8-0/WT-112.jpg)
I flat sanded the cuts to clean up the edges for a close fit.
(http://i1234.photobucket.com/albums/ff403/dave2-8-0/WT-113.jpg)
Used PVC cement and glued the wedges together, at the narrowest section, being careful to align the outside edges.
(http://i1234.photobucket.com/albums/ff403/dave2-8-0/WT-114.jpg)
All the wedges come together rather well and I have my spout tip !
(http://i1234.photobucket.com/albums/ff403/dave2-8-0/WT-115.jpg)
(http://i1234.photobucket.com/albums/ff403/dave2-8-0/WT-116.jpg)
I like the look, its shape resembles what a sheet metal spout would look like built in sections. Now to find the finished length of the spout, how to mount it, and the cables, and the counter weights. Oh ya, I got to plumb a valve for the downspout too. Had a little time to start banding the tank, Not as easy as it would seem!
(http://i1234.photobucket.com/albums/ff403/dave2-8-0/WT-106.jpg)
I think that it will really set off the tank.
