I bought a few of those AMS flatcars that were on sale back in January and I needed to figure out what I was going to make.
I like the idea of a ventilated boxcar, even though there weren’t very many in narrow gauge. I used this standard gauge car for inspiration:
So, the first step was to remove all of the hardware from the flatcar. There’s some nice brass steps that I’ll reuse, as well as the couplers and lift bars. I cut the rest off by running it through the table saw. Then I painted the top to look less red.
I got some scribed sheets from Ozark and cut them to shape. Then I used my little Microlux jigsaw to cut the openings. The vent openings were framed with plastic angle pieces.
I notched the back side of the vents to put in some .047" music wire. I was originally going to use some 1mm brass wire, but I really like the music wire as it doesn’t bend as easily. It is quite a bit harder to cut, but at least it doesn’t deform when I’m inserting it.
From the outside, it’s starting to look decent.
I don’t think I’ll do the doors at the top of each end, so these will be the only vents. Well, other than the side doors, of course.
