Thanks Guys -
Shawn, details have their good and bad points. Too many and the model becomes fragile and unpractical for the garden. Too few and realism is lost. It’s difficult to find the balance
I tend to get caught up in them because I spend so much time studying prototype photos. Then when it comes to implementing there must be compromises in order to use what is readily available and/or on-hand.
Bart and Bob coined the term “Operations Quality” which means just enough detail to be presentable, but not so much as to make handling and operation difficult. It usually means, among other things, no underside detail that can’t be seen. That’s kind of where I’d like to be at, but its hard deciding what to leave off. I really like the look of the cast detail items, but drilling all the holes to mount them is a lot of work.
I needed another set of ladders, this time I took shots of the assembly steps. 3MM PVC is ripped to width on the table saw then cut to length and shaped with a knife. Wood grain is added with a razor saw blade…
