Photo Update: Minimal progress this week, but I did spend some time on it today. I have been looking at the frame every meal while it sits on the dining room table. I decided that the needle beams and bolsters needed to be visible from the new outside edge of the car. The needle beams needed beefing up and extending. This was accomplished with a couple of strips cut from .040 styrene sheet and a chunk of 6mm PVC.
The extensions were made in pairs, then installed and glued on from each end…
The Delton bolsters have very little thickness at the car side. To extend them I glued together two pieces of .040 then glued that to the bottom edge of the car to represent the end of the bolster…
Additions with the frame in place…
I have maintained the ability for the frame to be removed from the body…
And finally, a track level view of the frame enhancements…
I also worked on the roof today. I have decided that even though this is a representation of a second generation wood car, it is a what-if the car survived to present day tourist operations. As such, I decided that the roof would have a tin coating similar to the extant steel frame boxcar. To represent this I coated the roof with aluminum foil tape. I started on the car lines but didn’t have a proper glue. I’d rather not mess with epoxy so tomorrow I’ll pick up some the 3M Emblem Adhesive to try.
Now if I could just come up with such a good plan to make the roof walk supports!
Thanks Kevin!
There are limits to my madness. Like all of the bolt detail on the roof and attaching the ladders. I’m just not willing to drill all those holes.
