I’m ready to start on a sound and R/C car for my FN3 trains. I’d rather not hack up one of my RTR cars from Bachman or AMS, so I decided to try my hand at up-scaling some of my 1:24 Delton Classic cars. I had a body & frame from a KRAFT Reefer that had damage and was cannibalized for parts. A perfect candidate for the saw. I spent an hour or so this afternoon removing all of the details. Some, like grabs and doors with hinges were removed. Cast-on detail was cut off with a razor saw. The entire body was then hit with an orbital sander and 150 grit paper. After cutting a speaker hole in the floor I ended up with this…
I will make the car wider and taller by gluing on 6mm PVC foam board. I’m considering trying to cut down some of Bob’s composite end 2nds to make this a composite car. If that doesn’t work out it will be a simple wooden car. I don’t have the budget for scribed siding so I tried scribing the PVC board with an awl. The boards in the photo below were not measured or squared, just a quick test to see if it will pass. The piece on the right was randomly scratched with several different saws to get ideas for grain. I’ll probably pass on adding grain.
I’m not sure yet if I will try and use the original roof as a base for an up-scaled roof, or just build one from scratch. Hopefully since there is a purpose for this car it won’t end up as another unfinished project.
They are scraps from my work at a sign shop.
As soon as that’s done I’ll take some progress pics of the body. EDIT to add a note: That brake wheel and shaft at bottom right is from a flat car that I was shooting over top of, not part of the box car.
