OK working on ideas and mock up’s for tackling the end plates on the cars. I’m gonna start with the transition dorm as I’m kinda disgusted with the roll of tape I’m currently using. Take note to the wavy lines on the large flat pieces but the bonus is you really cannot see these lines in natural light outside. I started with 1/16" pvc board as the base, cut holes for HEP cables, made the door surround from 1/4" square plastruct and the door itself is made with .020 styrene with black vinyl for a window.
(http://i45.photobucket.com/albums/f72/Shortybear/CVRR%20Locomotives/Superliners/Jan11008.jpg)
The sections are then put together and glued in place. Notice that the tape is done in 3 layers as it’s only 1 7/8" wide plus it adds to the detail with seaming shown.
(http://i45.photobucket.com/albums/f72/Shortybear/CVRR%20Locomotives/Superliners/Jan11012.jpg)
I laid the mock up on the end of the car and fairly pleased so far as its a good start. The diaphram(not glued or fastened yet) is from USA trains cut in 1/2. Dave “Hollywood” Marconi and myself had a serious discussion on this issue and it’s quite tedious to do. I’m not sure if I want to cut into the 1/4" pvc board on the end of the cars to make the proper recession for the HEP cabling. I tried on one side and ended up putting the piece back in and filling the cut line as it’s quite a bit of work for something that really will not be seen. I may change my mind on this though.
(http://i45.photobucket.com/albums/f72/Shortybear/CVRR%20Locomotives/Superliners/Jan11014.jpg)
(http://i45.photobucket.com/albums/f72/Shortybear/CVRR%20Locomotives/Superliners/Jan11018.jpg)
That’s all for now and hope to make some more progress tomorrow.
