This project has been in the ‘want to do’ file for a few years. I had a couple of old Pola buildings outdoors that were good candidates. They needed cleaning and fixing up after spending over two years outside. This was the perfect opportunity to experiment with lighting with a $0 investment project. I have a bunch of sign LEDs that were salvaged from old signs. Holy carp; can you believe scrap signs have LEDs already? They do
. They don’t take much 12V power to run and I have a variety of supplies I can use. I was once wired for track power, so what better power buss than the track ? Old broken Hillman clamps were cleaned up utilized as connectors wherever power is needed using Malibu wire & lugs from removed block switches.
First, light leaks were eliminated using scrap black sign vinyl. Orange vinyl was placed on the roof to warm up the very cold sign LEDs…
When the LEDs were quickly removed from aluminum panels being recycled, the plastic backs shattered but the circuit boards and wiring stayed intact and 90% of what came out still worked. To make mounting easy I just glued them to some scrap 3mm PVC board with 3M gasket adhesive. I found a tube of it when I got these Pola buildings used and falling apart. It works great on the Pola plastic as well as the PVC and circuit boards…
The PVC board is cut just a bit long so it force-fits between the walls held up by the upper windows. LEDs on top bounce off the orange vinyl…
More light leak stop using black vinyl and PVC board…
Next - The church gets the same treatment. Stay tuned.
