FWIW, I’ve been using LED tape on a several work-related projects over the last couple years, and plan on using it for my mine building. Here’s an example.
https://www.amazon.com/dp/B00JQV6SFU
You cut the stuff as needed, and solder the lengths via the solder pads. Approximately 2.5" is the cutting / soldering opportunity. It’s heavily potted with silicon, and seems quite waterproof (from the exterior side). However, it is therefore a small pain to expose the solder pads: you have to cut away the silicone. No huge pain though.
For securing it, don’t rely on the adhesive backing. It isn’t reliable in the long run. I use 3M VHB tape to secure the stuff, which is very tenacious.
Bottom line, I think it’s very usable and a great deal. I haven’t seen specs on current draw per foot, but if someone cares I’ll measure a sample.
===>Cliffy
