Tender finally buttoned up
Spent the day today mounting all the electronics and making the final splices and connections. I made sure to test operation at each step; good thing too 'cause as soon as the sound board was connected I had a problem with a missing trigger ground. It was an easy fix before everything was tied down but would have been a real pain to do after.
So here’s the electronics & wiring in it’s final configuration…
Even with all that wire management going on it was still quite a challenge to get the tender shell on. I had an unexpected fit problem when the screw from the tail light kept the tender from sitting fully down on the deck. A little filing of the the RailBoss board top edge was enough to allow a complete close.
Here’s the back-end with all of the tender detail back in place…
The back still needs the step plate and coupler pocket put back on. On the front end I still need to address the space problem keeping me from closing the boiler. I picked up a micro-mini SPDT at Radio Shack today that I’'m hoping I can make work in the space I have.
