Cramming for a test - a test fit that is. It’s tight, but I’m able to fit all my components less the batteries in the original tender with only the mods shown earlier. I wanted all the components to be mounted to the floor so the shell could be removed for programming if needed. First I mounted the RailBoss board as close to the back as possible. I used a single threaded right angle bracket from my electronics junk box. Luckily, the hole through the floor just grazed the inside of the frame rail…
Next I temporarily fitted the upgraded speaker and rested the Big Sound 97 on one side. The volume switch seen stuck to the magnet will go back in it’s sneaky spot under the removable valve on the tender deck. I’ll hot glue a piece of styrene to the magnet then use foam double-sided tape to attach the sound board…
On the opposite side the receiver will be hot glued directly to the magnet…
The view from above…
After tucking wires out of the way it was time to test fitting the shell. It was a little tricky getting it in place, but once there it sits down where it belongs…
The on/off switch and charge jack (if needed) will be mounted on the smoke box front. Next up is to work up the wiring plan and start hooking things up. Finding a place for all the wires is going to be a challenge.
Great work so far.
