Post-TrainOps layout work
Whipped up a spacing jig for the bridge ties. Should speed up assembly.
Sure is! Looks fascinating.
http://www.wymann.info/ShuntingPuzzles/sw-inglenook.html
Peter;
Good reading, but mine is somewhat different. Since I was pressed for space, I used a Roco three-way turnout, which allowed for more generous siding lengths. Still, the entire switching (shunting) puzzle had to load as a unit into the cargo area of (then) my 1981 Subaru GL wagon. I carried both modern era (for 1981) and grouping era shunting locomotives and wagons plus the power packs in a large fisherman’s tackle box. And used the “tiddlywink computer” featured in an article in Model Railways magazine to randomize wagon selection. That version is OO, but I had a similar track arrangement for the yard on my former garden railway.
Regards, David Meashey
And like any good jig, it went through a couple iterations to end up here.
Those are some nice beefy beams Bob.
Pin nailing them? How long are the nails? Of maybe a different type of fastener?
And do you bother with Titebond (III), and does it really hold after several years?
Echoing Craig, Bob, can you post a track plan to help everyone understand the line, and the mod’s you’re doing?
Glue and 18ga pins. Seems to hold up pretty well so far.
I dont currently have a track plan, I’ll have to draw one up, but my layout changes a lot so I’ve never really bothered. :slight_smile:
Do not forget the official napkin plan !
Craig, here’s Bob’s track plan.
A little out of date. The protrusion toward the house doesn’t exist anymore, and a whole bunch of other track has been put in, but you get the idea.
:crazy_face:
Bob,
Would you consider sharing your jig stl. on your Printables site?
Here ya go, Bill
https://www.printables.com/model/960001-trestle-deck-jig
My ancient and venerable Craftsman brad nailer finally stopped working. Not surprised, it’s something like 25 years old. While I figure out how to fix (or just buy a new one) I’m still making progress gluing ties.
I’ve got a framing nailer that refuses to fire every time I go to use it. I take it apart to try and fix. Can’t find anything wrong so I put it back together and it will work fine until I set it down for more that a few minutes! Rinse and repeat! I don’t use it often enough to replace.
I’ve already had this one apart a few times. The safety widget gave up the ghost a few years ago so I had to bypass that. Just took it apart, and the anvil that is driven by the electromagnet solenoid is warn thin and broken. Ugh. Replacement time!
More power ugggg ! :stuck_out_tongue_winking_eye:
About a third done with gluing bridge ties, so I thought a quick mock-up of rail and guards would give everyone (including me!) an idea how it will look.
Does it fire and not drive a nail or not even fire ? I have one new, it will fire but no nail, oiled the rail and it is getting better.
I was gonna say oil , oil , oil (I like 0/20 mobil one myself) on everything and it usually buys you time …lol
Gonna edit to say I just reread as suggested and it sounds like BD’s gun is electric and not pneumatic !
Here’s what is looked like in 2019…but only more from the ground. :innocent:
And 2022…
Another 2022…
I have LOTS more, but I really want to thank EVERYONE that does this sort of thing- it’s a LOT of work and Jean & I REALLY appreciate it. Lots of fun for the attendees. :grinning:
Does not fire. Leaks the air when trigger pulled. Open, clean, lube & assemble then it fires.
