The doors to the vestibule area are made up of three pieces.
(http://www.jbrr.com/Pics/RollingStock/PassengerCars/CoachProject/IMG_0246.JPG)
The first two are the “skins” to the door and are laser cut styrene. The inner door is made of clear styrene and sandwiched between the other two pieces. I cut the styrene to the size of the door.
(http://www.jbrr.com/Pics/RollingStock/PassengerCars/CoachProject/IMG_0247.JPG)
Unfortunately, I wasn’t thinking when I painted the skin - I should have painted two of them the inside color. So, a bit of delay while the other side was repainted. Too bad I didn’t realize this until AFTER I had glued the clear styrene in place. I painted the ends of the side pieces, as I didn’t want to have to mask later. These were painted inside AND out with the exterior color; I thought the inside of the vestibule would be fine in that color.
(http://www.jbrr.com/Pics/RollingStock/PassengerCars/CoachProject/IMG_0251.JPG)
These are then glued in place. Tabs on the interior partition walls fit into slots on the side pieces. There are also some tabs on the bottom of each side that fit into the floor section. The vestibules are made up of multiple pieces; I first painted the INSIDE pieces.
(http://www.jbrr.com/Pics/RollingStock/PassengerCars/CoachProject/IMG_0249.JPG)
Note that in the production model, I asked Alan to eliminate the tiny pieces and little slots - they really don’t add any strength to the assembly. Best bet is to just bevel the edges a bit and glue them in place. - They WILL be covered by exterior skin later.
(http://www.jbrr.com/Pics/RollingStock/PassengerCars/CoachProject/IMG_0254.JPG)
I wish I had taped the edges to be glued on the side pieces BEFORE I glued the sides in place as it made scraping the paint a tad more difficult.
It turns out I glued my chairs too close to the walls - I will have a bit of trouble gluing the inside window frames in place. Hehe…all sorts of things I should have done differently.
