Well I got to piddling with the idea of more ore cars. And of course you can’t get anymore from Western Scale Models. So I decided to make my own. Yes you can get some from Ozark Miniatures but at $33 each. I can make my own…
As y’all probably have figured out i am not a rivet counter. So I looked around the internet for different types of ore cars. I ran across a drawing for a wood ore car. I have not seen one of those done. So i figured I would give it a go.
Last night i started with the wheel. I took an old 25 gallon barrel that I cast and it was slightly over size of what i needed. I chucked it up in the lathe and produced 1 wheel. It turned out pretty good. I made a master mold of this and then cast more . I will make a second mold of 4, so i can do 4 at a time…
Well I got to piddling with the idea of more ore cars. And of course you can’t get anymore from Western Scale Models. So I decided to make my own. Yes you can get some from Ozark Miniatures but at $33 each. I can make my own…"
Boy I didn’t know Ozarks Miniatures got so expensive… I got mine as a kit with the man for 18 bucks if I remember right long time ago.
We’re watch the build.
I don’t blame you on making your own and looking good do so far.
Here is the second ones out of the mold. When casting real wood if I don’t seal it, all the trash ends up in the mold. So the first one cast pulls all the trash from the mold.
I did put rivets on the body and I cast the door separate,so it will be functional. I use pins for the hinges
Here is the first one painted. As always you have to wash the castings and then I primed them with a ruddy red primer. I painted the wood with a desert sand acrylic and them used chalks the darken the colors. Then went back with a rusty rail color. For the metal parts. Once dry dry brushed with a Barnwood acrylic.
Hopefully giving it the crimey look of use in a mine…
