Devon Sinsley said:
OK,
In another thread, Steve questioned me about my battery placement. This is a good time to open this up for discussion for my build. There is zero room in the loco for anything but wire. I was thinking and using advice that I can not remember where I got it, that I should place the RC unit, speaker, and sound card in the tender and use separate battery cars. The thinking being 1) I wont have room for it all in the tender and 2) when the battery dies I can simply switch out battery cars and keep on going. That way there is always a fresh battery. However, I can see the disadvantage of having a separate battery car in that your loco will always have to have one of those cars in that position all of the time.
So I am soliciting advice. I plan on using the RailBoss 4 5-Amp version for loco control. I know nothing about sound systems so don’t know what to buy there and I will use the Bachmann speaker that came with the ten wheeler unless there is a reason not too. How much battery do I need? Will it all stuff into my tender?
In other words, what are you all doing?
Devon, Bruce mentioned enclosing the speaker in a box. This is to reduce the reverberation from the sound waves coming off the back of the speaker, and setting the plastic of the tender’s walls to vibrating a nanosecond or so behind the front of the speaker. Its noticeable. The enclosure cuts that down, dramatically. To stop it completely, fill the enclosure with cotton, to adsorb all the vibrations coming off the back of the speaker. The difference is dramatic.
Phoenix supplies a speaker with their sound card. Use it, instead of the cheap Bachmann speaker. If you are going to use a different sound card, good speakers in the size we use are inexpensive.
I don’t know the size of the ESC that you are planning to use. Del makes some good stuff, talk to him direct, he will make sure that you have the right application.
Sound cards are small and easy to shoehorn in.
Leave the battery for last. A LIon 14.8 volt 2800 mAh battery is the size of 4 AA’s. Easy to change out when the run dry, just pull the coal load (wood) off, unplug, and plug in a fresh battery. You will probably run out of enthusiasm before the battery runs out of juice.
Enjoy.
