Here is the cab. Pretty much finished. Need to put on the front doors and and the mounts and then it will be time for paint. I leave slots for sliding in the clear plastic for after it is painted. Then you can slide the clear plastic in and tack in place. The doors will be made with working hinges on the front.
The front of the cab is separate from the rest of the cab and will be attached permanently so I can run my plumbing and stuff through it.
I am thinking of adding masking tape to the roof in layers to simulate tar paper. Has anyone done this. Recommendations or a better way?
