Pete Thornton said:
John Caughey said:
Are you going to run this engine? You’ll probably need weight on the front truck, adding weights is a B’mann fix.
John
Devon,
The “weight on the front truck” fix was for the long 4-wheel pilot truck on the 4-6-0. It was very rigid and didn’t track well on bumps. I personally never added weight, I just made it more flexible and it never derailed.
(I could make strong case for flexibility on your front axle. It should be able to rock about the center line of the frame by about 1/16th inch.)On a 2-6-0, the pilot would help the drivers take the side forces as they hit the curve. Technically the pilot needs a centering spring, so on a curve the outer wheel is helping pull the loco round the bend. In practice, it hardly ever works on our trains, as we don’t have the same weight distribution, flange sizes, etc.
While a couple of washers won’t hurt, a light spring is all you may need on your 2-6-0. maybe not that. I’d try it before you add weight - you can always add some later.
I am toying with a spring. Where it is mounted now I could put a spring there and move the pivot point back. But I don’t know how I would do it so that the spring could pivot back and forth as the pilot pivots. I have to think about this.
