A little more progress. Got another 5 main posts, and half a dozen small ones in the other weekend with some help from club members.
That clears the way to build some roadbed and set up the yard entrance. I did some sketching, if I allow a 2m transition from the flat yard to mainline 1% downgrade I can put the entrance turnout on the downgrade. Winter task is to build a curved turnout for that bit, once the roadbed is done.
I also started looking at the upper loop & mine trackwork. I want to set up scenes in different parts of the railroad and this seemed a good place.
Here’s the first cut.
I’ve got the mainline going up at 1%, and the mine lead down at 1%, that creates a height difference of 70 mm as the track finally heads out of sight through a tunnel. The other end of the loop disappears behind a rock bluff just past the yard.
Here it is painted out on the ground. Best part is the mine looks like it’s going to be outside the lift area for the container so I’m figuring I can build that next.
Slowing down a lot now, very little daylight after work so build time is only on weekends outside chores…
Cheers
N
), the pine comes from the sawmill fresh from steam pressure treatment. If left alone it turns into a serious pretzel within a few days - there’s always a reject pile at the timber yard that no one will touch, we all go for the straight bits a few layers down.
