Okay, I’ll go back to my original thesis that I was developing when I remembered the pistol grip R/C controls. (Incidentally, I use one for one of my locos with great success. You take the centering springs out of the trigger and knob.)
Why does this unit have to be “low cost?” The “low cost” option for control would be the standard 2-stick transmitter. You can get those pretty inexpensively. If you’re going to try to undercut that, you’ve got a tall, tall order ahead of you. It seems to me that a smaller, hand-held controller with proportional control over multiple channels would be a premium controller. Compare the basic AirWire controller to the NCE G-wire controller. The AirWire controller has a knob, direction switch, and 10-digit keypad. That’s it. The NCE controller has a thumbwheel and buttons galore. You can program macros, options, any number of things. Ultimately, both do exactly the same thing, it’s just how they do it–and how the user interfaces with it–that’s different. It seems to be worth the premium, as people like it. You don’t “need” it, but it sure makes running the trains a bit more intuitive.
In my opinion, the same would hold true here. If you want the basics, you go with the cheap 2-stick controllers. You get all the control, but in a form factor that’s far from convenient. However, for an additional price, you can get a smaller, handheld controller that offers the same level of proportional control in a smaller package that’s easier to carry around the garden. There’s no reason it needs to be as small as the RCS Elite controller. I think you could easily get away with something the size of the Revolution or Airwire or old Train Engineer controllers. That seems to be an acceptable size range based on what I’ve heard people say. I personally think the NCE controller is a touch larger than ideal, but that doesn’t keep me from enjoying using it, either. It’s still one-hand control.
Forgive my frankness, here, but through all this discussion, I keep hearing an overall tone of “it can’t be done.” I’m not convinced. I’ve not heard one shred of evidence why you can’t fit three, four channels of proportional control in a small, handheld package. Even if the pistol-grip transmitters aren’t ideal, they do put all the controls in the head of the transmitter. Cut the handle off, and it’s about the size of the old Train Engineer transmitters. Can it be done for less than $200? That, I don’t know, but what I’m hearing is an overarching reluctance to even consider it for fear that it might not be. To me, that’s a bit backwards. Work on the ideal, figure out how physically to make it work, then start figuring out how to produce it fairly cost-effectively. If–at that point–you find it can’t be done, then start paring down functions. But by choosing from the start to only produce one proportional control, I think you’re going the wrong way about it.
I started off with using 2-stick controls, and will never go back to them. They’re cumbersome, plain and simple. For my fire-breathing dragons, the pistol-grip controls hold promise. They’re not ideal, but they’re a step up from 2-stick controls. At least I can use one hand to control the throttle. I’d love something even better. Give me a small form with comparable functions for around $200, and I’ll write you a check. But I need proportional control over more than one channel, plain and simple. Don’t do that, I’m not interested.
