Kevin.
If you think cost is not a factor you are living in LaLa land.
Using off the shelf 2.4 GHz multi channel stick radios is the lowest cost way of achieving reliable proportional control with long range and no “Glitching”.
A 6 x channel EXCEED TX and RX can be delivered to your door for US$45. Compare that to the cost of Revolution, AirWire or G-Wire TX’s.
Extra RX’s are US$15.
Add a 3 amp ESC for say US$80 - $90 and you are ready to go for US$125. The cost of the ESC’s will come down over time.
For this you will get DIGITAL PROPORTIONAL (DP) speed control, four sound triggers and the ability to control a quillable whistle if and when they become available.
To transpose the way it works into a smaller package is doable. Just not with all the levers and buttons on the current stick radios. It is the mechanical hardware that costs the big bucks and takes up the space. Not the electronics.
You will only need DP for speed control and the quillable whistle. No need for any of the complicated multi plane stick mechanisms, trim buttons or servo reversing.
Two pots and four switches will suffice. That is what will make it affordable. Maybe three pots and three switches for live steam.
It would need to sell for less than US$50 to make it viable.
Steve.
The BELTROL ambition was to produce a belt mounted TX that simulated the way the real life BELTPACK system works.
I believe that would actually be easier to do than a miniaturised TX such as we are discussing. But, once again the cost is in the hardware.
