First of all, The K-27 gearbox HAS a worm gear and a double thread at that. I have the gearbox and it is opened so I can examine and measure.
Second, The spec sheet for the 8000 series motor is not for the best performing motor, in my opinion and experience. I went through the 8000 series spec sheets 15 years ago and selected the highest performing version available in the optional specs. I selected the 19.1 volt version for the best mix of specs and the best match to the powerpack output at the time. NOTE: the 19.1 volt version can tolerate 30 volts for short periods, not recommended, but is it’s “safety factor”. I selected the ball bearing version due to the zero-end play availability. In the first few orders I had the motors delivered with single shaft and end terminals. I changed that order to get the side terminal version. The reason was that the end terminal version does not permit changing the brushes without special equipment, the side terminal version I can change out. This meant having to buy a 50 brush sets. I also ordered the side terminal version with double shaft (the shaft is out both ends of the motor). I also specified .125" diameter shaft. Standard shaft is 5/32, in hindsight, I could have used the stock size shaft, but I started out buying what was commercially available and some years later had my own worms developed.
NOTE: An"Order" is for a quantity of 100 motors.
I’m sure I have forgotten something, but this should do for now.
Barry - BBT
