Help me here…I’ve always been taught that correct gearing is the crux on most anything mechanical…see added bold below…
Quote:
. . Posted by: "Stan Ames" Fri Dec 5, 2008 2:17 pm (PST)— In [email protected], dave funk <dsfunk2@…> wrote:
Stan, I always thought gear ratio had a huge
impact on a model locomotives ability to pull a train. Gearing must
also match the size and torque specs of the motor. My Bachmann K-27
runs ok but it would run and pull much stronger if it had a gear ratio
in the 28 or 30 :1 range ( like most other model steam locos do ).
The way the K-27 is geared Bachmann is relying on the torque of the
pitman motor to compensate for an incorrect gear ratio ! Why not just
correct the mistake and issue the correct parts for the locomotives
that are already in service? I enjoy my K-27, I just wish it ran as
good as it looks!
Dave Funk
Dave
You are correct gearing is critical to proper operation. But there are
limits.If the motor stalls under any load then indeed the motor/gear ratio
combinationwould not be sufficient and would greatly effect the ability to pull a
train.In the case of the Bachmann K27 the wheels will slip when the load is
greater then the ability of the locomotive to pull the train. This is
exactly as it should be.
In order to increase the pulling power of this locomotive you must
increase the traction on the wheels by adding weight (or dare I say it
traction tires) [b]Changing the gearing alone would have negligible
effects. [/b] On the other end, if the gear ratio is to high then the top end
speed of the model will suffer and you may not be able to achieve
prototypical speeds. The gearing, the motor, and the entire drive train
all contribute to the locomotives operation. In the case of the
Bachmann K27 they do indeed rely on the excellent motor they have in the
model as well they should.
On my railroad my K27s will pull trains up the grade that are longer
then the longest sidings on my railroad, it will start a long train on a
steep grade smoothlyand with ease (see the video I posted). So for me it works just fine.
I have extremely good slow speed power under all load and grade
conditions.INcreasing the gear ratio of a model is not always the right solution.
Forexample if you were to replace the gearing from 1:14.5 to 1:30 the top
end speed of the locomotive would decrease substantially/ likely by
1/2. I say likely because if the K27 is over tasking the motor (I do
not think it is) then themax RPM will increase as well as you increase the ratio so the decrease
in top speed may not be the full 50%. When you drop the top end speed
you run into the other side of the problem. The model would not be able
to operate at its prototype top end speed at 18 volts DC. I have some
locomotives that my operations always run at their top end speed because
they run to slow and others where you can not get a reasonable speed at
all. For the K27 my operators typically operate them at a speed step
from 16-24 out of 28. This is great because they will change the speed
as the the train traverses the railroad. In the video the speed was
about 16/28 which is close to 15MPH or so.
If you ckeck out the Bachmann K27 videos various folks have posted on
you tube, you may be as surprised as I was at the speeds they run them
at. I point this out because there appear to be a substantial number of
modelers that enjoy operating their trains at perhaps a little faster
thenprototype speeds.
[b]What the manufacturers need and we as modelers could provide is the
desired top end speed at a specified voltage.[/b] Myself I believe that
prototype top end speed at 20 volts DC would be just about right. That
would allow faster speeds at 24 volts DC while allowing modelers to
lower the voltage and still get excellent speed range for their models.
For the K27 I think a speed of 40MPH at 20 volts might be a good
compromise between those that always run their locomotives at a crawl
and those that would like to run them prototype running speeds.
As for having a replacement gearbox, thats a question you should bring
up with Bachmann.
Stan
www.tttrains.com/largescale http://www.tttrains.com/largescale
