The only “leaked” information is that it is a custom-wound 24V motor (want to believe that? Their on-line catalog STILL shows the K as having a 24V motor).
“custom-built 24 volt Pittman motor with double shafted brass machined flywheel”
http://www.bachmanntrains.com/home-usa/products.php?act=viewProd&productId=2031
The video cals the artic motors as custom-wound 24V motors.
Is this more obfuscation?
Rumour is they are NOT Pittmans, but, that’s a rumour.
Zubi, the K draws over 5 amps at full slip.
The motor is rated for 1.7A continuous.
The gears are too tall.
I’ve tested it, I know what it does.
Even the Obfuscator himself shows a video of 30 cars on a 4%, except, listen carefully, and you will hear the REAR END PUSHER start up, then the MID-TRAIN HELPER start up, THEN the lead loco starts.
You have a large enough power district, okay, but I know with 20 cars on a 13’6" diameter 4% grade, one engine is over three amps.
Yet, with 29.9:1 and a Pittman, I know what a 4-6-0 or 2-8-0, even an outside-frame 2-8-0 will do.
