Stan Ames said:
I am pleased that your findings and mine are indeed similar. That helps communicate
The ability to communicate requires the respondee to actually listen, pay attention and comprehend.
So we can agree on something.
Stan Ames said:
If the gear ratio was changed to 1:30 as you desire then the locomotive top speed would half and at 18 volts DC the speed would be 20MPH or a little more then the top speed of the Bachmann Shay.
Yes. If they need to go faster up to say 30 mph then the would need to add extra voltage. Most controllers will get close to or exceed 24 volts.
By your own admission elsewhere you agreed the speed ratio would not be all that exact anyway do to freeing up the load by having a lower ratio.
My experiments with numerous K-27's has shown they go plenty fast enough on less than 14 volts output of the controller. I know of no one with anything like a graded or curvy track that has run them flat out.
Stan Ames said:
SNIP
Most of my engineers on my railroad operate the K27 at about 30-35MPH on long runs. On a large layout this still appears slow and is much slower than what many large scale modelers operate their locomotives at.
I can only assume you lowered the voltage output from the on board decoders, otherwise they would be ending up in the boonies very quickly.
Stan Ames said:
Like it or not the manufacturer of a mass market model needs to try to satisify the needs for as many modelers as possible. A K27 with a top speed that is much less then the prototype top speed and deemed by the modeler as to slow is just as bad as one deamed to fast.
I guess that is an admission that catering for the great unwashed is more important than getting it right and relying on quality to sell a product.
Stan Ames said:
To comminicate to a manufacturer you do so in speed at a specified voltage. Asking them to drop the top end speed by 10-20 percent is something that can be explained and justified. Dropping it by 1/2 to a speed much slower then many modelers want to operate it at is a non starter.
SNIP
Speaking on behalf of the operators on my railroad the 2-8-0 has a top speed that is bairly adequate and most times that locomotive is run at full speed. The operators enjoy operatng the K because they need to pay much more attention to the actual speed than they enjoy acting more like an actual engineer.
I hope that explains the different views that one can have about speed.
Stan Ames
www.tttrains.com/largescale
So all those operators of Accucraft locos, with most of the locos with roughly 30:1 gearing, are wrong to accept that ratio?
Why don’t you trot along to a forum that specialises in big Accucraft locos and try and convince them to change the gearboxes in their locos because they don’t knowhat they are missing out on.
Oh!!! silly me. You did that already.
