Dan Hilyer said:
Nice work, Devon. Did you print the rods or did you fabricate them? I like the yellow, it will go well with the pink engine (https://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-wink.gif)
The side rods are bachmann big hauler side rods with the center hole cut away and the two ends married at one side. The white “knuckle” on one side is used to make a socket to join and strengthen the two pieces together. Then the otherside just balances it out. The drive rod is from a bachmann lil hauler side rod with one end cut off. The rest is fabricated out of pieces of brass and copper soldered together.
