So thanks to Ben I am delving into yet another scale, Fn2. For those not in the know this is 1:20.3 scale models run on 32mm track (O gauge). Since my layout theme is a 1:20.3 Fn3 narrow gauge, it works. I have no more plans than to just dabble in this. I have always had a future plan for expanding the outdoor to have a long spur to a mine that would then come in above my current layout and dump into an oar bin for loading into side dump hoppers I have. Since that is a blank slate, and would have need for more track anyway, it really makes no difference if the track I put down is 32mm or 45mm since they won’t be innertied. I even have an old O gauge motor block. So this challenge was tailor made for a small mining tram locomotive. So without further ado here is the napkin blueprints for the Procrastination, Daydreams, & Unfinished Projects (P. D. & U. P.) locomotive #19 “COVID” in Fn2. Its a knock off of a Portor 0-4-0 compressed air loco that I will be adding an additional tender to. This will be RC/Battery and the tender will hold at least the batteries and hopefully the little RC board I have if I can find it.
Here is the prototype I am roughly after made by Porter.
