Okay, here’s the post that started this whole thing (from page 2)
Kevin Strong said:
Fred Mills said:
...[b]If you are hoping for a 1:20.3 scale K27, from B'mann, that will negotiate an 8 foot diameter curve; you must be really drowning in LGB mentality...[/b] [i](Emphasis mine. Here's the second line of Fred's post, which I omitted from my original.)[/i] I'll be surprised if the minimum radius is less than 6 foot, or 12 foot diameter, for the K27, as the model will be closer to a scale model than anything LGB ever thought of producing.
Fred, why not? Accucraft's Ks (even the K-37) negotiate 4' radius curves. I'll agree, they look a might silly doing so, but they do. The only compromise that I found on Accucraft's K-37 was the lack of flanges on the center two drivers, where the prototype had flanges. There's no reason in my mind to expect Bachmann's loco to need more.
That singular proposition from Fred is the [i]only[/i] point that I have been debating. Perhaps I should have singled out the K-37 instead of generalizing all Accucraft's locos, as that's the only one I have firsthand experience with testing. To my knowledge, however, all Accucraft Ks are spec'd to run around 4' minimum radius curves. The K-27's specs are no longer posted on Accucraft's website, but the 28, 36, and 37 are. (As are the EBT mikes from both Accucraft and Rich Yoder. His ads are wrong; got that from him personally.) I was unaware of any of these models' apparent inabilities to meet those minimum stated specifications.
That is the closest I ever came to saying large locos could fit around tight curves. I modified my position to limit the discussion specifically to the Accucraft K-37 once I was made aware of examples that have come up short. I certainly have no reason to doubt Dave’s observations, and I would never say they were wrong. But those shortcomings are irrelevant to the single task of rebutting Fred’s original proposition, which was my one–and only–point. So long as one locomotive has shown that it is physically possible to successfully negotiate a 4’ radius curve, it stands to reason that future models can if the manufacturer decides to pursue that as a goal.
In truth, half of Fred’s proposition is accurate. While it has been demonstrated (at least with one example) that it is possible to fit such a large loco around such tight curves, the aesthetics of doing so do reek of “LGB mentality.” A loco that size looks no better going around a 4’ radius curve than the LGB Mogul does going around a 2’ radius curve. I think the K-series locos (and others of that general size) would look best on 6’ or larger radii. But from a marketing perspective, I can see where making that minimum benchmark is a desirable thing.
Curmudgeon said:
... Nobody said custom modifications. Gotta watch them media glasses.
Sorry, TOC, I interpreted that as you thinking the K-37 was modified from its original form. My apologies for the misunderstanding.
Curmudgeon said:
You have one example that will.
To say that someone can drag their 1:20 brass K-27 out of storage and do that (which is what your dissertaion leads us to believ initially) ain't gonna happen.
Boy, I wish I knew how you were interpreting my argument as leading one to believe that. But--as above--misunderstandings happen. The "one example that will" has been the focus all along. Yes, I mentioned the K-27 in the original post, but you told me it couldn't, I believed you. Why would I continue to say it can? You know I take you at your word. I only needed one example to prove my point that it can be done, and the K-37 illustrates that rather handily.
Curmudgeon said:
...Here is the original. It does NOt say you cannot, is says very few:
"Nice locomotives that only a select few can afford and very few can run on their layouts."
ALWAYS best to get the quote correct before you run off half-cocked
You're absolutely correct, TOC. Unfortunately, [u]you're quoting the wrong quote.[/u] That's not the genesis of this debate. If what you're quoting is the proposition you think I'm arguing, I can see how you may be misinterpreting my thoughts. Please re-read Fr. Fred's proposition, and perhaps my arguments will make a bit more sense.
Curmudgeon said:
...At least when I review Bachmann products I tend to keep an open mind.
That reeks of a personal attack, and I hope I'm just reading that wrong. But if that is indeed where you wish to tread, go it alone.
