Yes, you’re reading that wrong.
The unit you have, a 37, you report as able to leap tall buildings with a …oh, wait…wrong thread…go around 1600 curves.
That unit was not mentioned prior to your posting.
To pick one unit of a line and then (originally) credit all components of the line with the same capabilities wasn’t quite as “open-minded” as I would have expected.
You do seem to be redeeming yourself…slowly.
I guess since a Ford GP-40 does 196MPH in a flat, I could expect my 1972 Ford Pinto to do the same.
I try to reference back to similar components from the same manufacturer, specifically itemizing changes (for better or worse) from earlier offerings.
THAT was what I was getting at earlier.
The short drawbar of earlier units created real issues in some instances.
Obviously, this one has been somewhat changed.
Personally, I would have worded it something like:
While earlier units from various manufacturers of larger brass locomotives seem to have had issues with shorter drawbars, limited truck throw, and piping, this wonderful new unit has gotten around this problem in a unique manner that is not obvious to the observer and does nothing to detract from the scale model appearance of the locomotive in use on broader curves. While it WILL go around ex-lgb 1600 curves, it isn’t pretty doing so, and we have not yet coupled cars to either end to see if that is a possibility on these sharper curves".
