"Super Connie"
Sorry. Couldn’t resist that. As an old pilot (not a bold one) I still remember the Lockheed Constellation, a big four-engine airliner and military transport plane which was lovingly referred to as a “Connie” by its pilots just like we do with our Bachmann Consolidations. There was an upgraded variant of that airplane known as the “Super Connie” which I have taken to calling my B’mann bash. I hope that moniker is appropriate, it did come out pretty good, IMHO.
Also, following the practice of several real railroads for locomotive designation, I have dubbed it a C-20 because, size-wise, it sort of falls between a C-19 and a C-21 and I have seen a very similar Consolidation that ran on the White Pass R.R. that was rated for just over 20,000 pounds of tractive effort. As far as I know, that “other” D&RGW never had a C-20 on its roster, but my D&RGW does. (That’s the beauty of free-lance modeling, you’re not a slave to prototype.)
First, the official builder photos:
Some side-quarter shots:
I’d hesitate to start describing everything I did to this model - it would fill a couple of pages - and since most of you are already pretty familiar with the Bachmann Connie, I’ll leave it to you to spot the differences with the stock version. That being said, I’ll still be happy to answer any specific questions you may have.
The two most obvious changes are the addition of a smokestack and cowcatcher from an Accucraft C-21. I try to give all my locos a “family resemblance” by painting and equipping them more-or-less the same - so they look like they came from the same roundhouse and I’ve followed that practice with my “Super Connie”.
I used Richard Kapuaala’s wonderful portrait figure of Sherman Pippin of the ET&WNC (“Tweetsie”) as the engineer.
As you can see, I opened the back of the cab and shortened the backhead a little.
I exchanged the trucks on the tender with some metal Accucraft ones and lowered the bolsters somewhat. The air tank came from Accucraft.
The pilot deck and truck were shortened about an eighth of an inch each. The breaker bar was scratch-built for the working Accucraft coupler (same on the tender end.) I also reduced the height of the sand dome a little bit, added a lid and swapped positions with the bell.
This is only meant to be a “suggestion” of cab interior details rather than an exact duplication. I used the original Johnson bar - which was very short - to rig up a throttle quadrant.
Here’s the electronic “guts” of the thing. The on/off switch and the charging jack for the 14.4 volt lithium-ion battery pack are hidden in the water fill trunk. Since my lithium-ion charger looks very similar to my NMH one, and they use the same type plug, I’ve painted the recharging jacks on the lithium-powered locos and the plug on the recharger a bright yellow to make sure I don’t accidently use the wrong charger, which could cause some real problems. The battery pack fits under the air tank inside the tender shell. The AirWire receiver/decoder and the smaller Phoenix P5 sound board are mounted on top of the speaker baffle and normally concealed by the removable coal pile. There’s a volume switch and a programming jack to the right of the P5. Holes cut in the bottom of the tender frame provide plenty of ventilation.
Here is a shot of the revised version of No. 65’s front pilot truck.
I used some metal castings that I had from Ozark Miniatures (their Part No. 1039).
Extreme Closeup
Here’s a few more shots of the cab interior and the tender that I thought you might enjoy seeing:
The fuel load is real coal, picked up in the yard at Chama, NM.
My thanks to Jonathan Bliese for finding this air tank for me.
I’ve been running his guy for some time now and I knew it was only a matter of time before the Delrin drive gear gave out - and sure 'nuff" - it did recently. Turned out fixing it was a lot easier than I thought. Bachmann supplied a replacement driver axle with a brass gear affixed and it was just a question of going up from the bottom, removing the old one and installing the new one.
Anyway, that’s about it. Now it’s a pretty much unique engine that looks a lot less Mexican and a lot more Colorado. Man, this little “vest pocket” Connie runs sweet - I just love watching that Baker valve gear work as it glides along with those counterbalances spinning.
