I just received the 2 Kadee coupler gauges I ordered:
Kadee 980
“New Generation” G-SCALE Coupler Height Gauge
#906 AAR Type “E” Couplers, “Prototype” Head
Centerset Shank Couplers & #910 (#830) Body Mount Gearboxes Black
• Hidden Knuckle Spring.
• AAR Type “E” Coupler Style.
Kadee 1929
“New Generation” #1-SCALE Coupler Height Gauge
#1906 #1-Scale Centerset Shank Couplers & Body Mount Gearbox
980 on the left, 1929 on the right:
from above:
G-scale and
#1-scale DONT align along horizontal centerline! I assume it is because of the
different scales of the 2 couplers…
MTH Daylight with factory truck mount coupler (980 gauge):
Coupler is too low!
MTH Daylight with a Kadee 1906 #1-scale body mount coupler (1929 gauge):
Close - the 1906 is attached to the MTH factory body-mount coupler holes.
MTH Daylight with a Kadee 906 G-scale body mount coupler (980 gauge):
Kinda-close - the 906 is attached to the MTH factory body-mount coupler rear hole (the side holes don’t match).
The fly in the ointment is the MTH factory wheels:
1.0375 tread diameter
which translates to 33.2", while the Daylight Pullmans had 36" wheels.
Gary Raymond offers:
1 36 RDLE (1.125" tread diameter) Dual Ball Bearings with Electrical Pickup in RAIL-GLIDE™. FOR MTH PASSENGER
which is exactly 36" @ #1-scale. I may go with:
1 36 RDLN (1.125" tread diameter) Dual Ball Bearings with No Electrical Pickup in RAIL-GLIDE™. MTH MODERN FREIGHT
as I don’t need/want electrical pickup.
The proper sized wheels will raise the car another 0.04-0.05". The 1906 is already a hair high on the existing MTH car, so I can adjust it to “perfect” with a shim.
I’m still totally conflicted as to whether to go with G-scale or #1-scale couplers ![:thinking: :thinking:](https://largescalecentral.com/images/emoji/google/thinking.png?v=10)
