As Fred is fond of saying, A model RR is never finished. And, after hosting a couple of Ops sessions, I felt there was a need for a bit more room for guys to store the locos when not in use. Also needed was an out of the way spot to off load and load their locos. With that in mind, and a 16’ blank wall to work with on the west side of the shed, a plan was formed.
The ground here is higher then where the TT is, so access to it will be just a matter of turning the corner. The TT will be used as a bridge to connect this area with Delores Yard. It will also give me a place to set the engine house, which has been sitting in the shed for a few years. This will also allow me to move the engine servicing facilities to this spot (those 3 building in the upper right), allowing more track to be utilized in the yard area.
If the weather holds out, I may be able to start on this before spring. And hopefully have it ready for the next Ops session in April.
