Operations on the J&B is normally pretty involved. I have to set out almost 40 cars across the layout. Setup can take about 1/2 hour. By the time I run two trains and put everything back it’s about 3 hours total. I don’t always want to spend the time, unless I’ve got a guest coming.
I needed something quicker.
Inspired by “Inglenook Sidings”, I decided to create my own little operations scenario, but using my “rules”.
The first step is to put out 11 cars. The top most track is the caboose track, so I won’t use it at all. The track at the bottom is my arrival-departure track, so it is also not used.
I took 25 pennies and painted them three different colors. I then numbered them. The yellow and gold pennies are numbered 1 through 4, and the cream pennies only 1 to 3.
I take 11 cars out of my storage shed and place them on the yard track. 2 Pennies of the same number are put on top of each car.
Now I remove one of the pennies from each car and randomly draw 5 of them. This will be the order of the cars for my train.
I then start building my train.
Cars that are not part of the train must be put back on the same track they came from, although order does not matter. I use the plain pennies to help me remember the track they started on.
I am not allowed on the A/D track at all. The track next to it can hold about 5 cars, although there are only 4 in this picture.
Here I’ve just got to connect the three cars behind the loco with the two on the other track, and I’m done.
It’s not a tough puzzle at all, but it is quick and fun. The pennies will add some randomness to each session. It was also a good test of my rebuilt switches; no problems at all.
