So, inspired by a discussion on Vic’s N-scale thread, I decided that it would be amusing to re-create my G scale layout in miniature. I’m going to try and capture the essentials of my backyard layout in a Z scale layout that will fit on a flat car.
To start with, I wanted something pretty big, but I didn’t have any large flats. I did have a Newqida passenger car in my parts bin, so it was off with the roof and body. Next, I bought some Z scale “R45” curves. I’ve used Rohukan track on my shelf layout, but I hadn’t seen these tiny guys until Greg E mentioned them. It’s funny (to me at least) that these curves have approximately a 45mm diameter–the width between the rails in G.
Since they fit nicely, it was on to thinking about the things that I like most about my outdoor layout. The two that I like best are my steel bridge and alpine mountain. So I needed to recreate these in Z, but at a size that would fit on a flat.
The bridge was easy. I made a template on paper,
then used balsa to build it
The mountain is a balsa shell with paper mache–just tissue and glue, really
Then painting
Here they are on a piece of Sintra that I’m going to use for the base. There’s a piece of paper behind the bridge as it didn’t show up against the black table.
