whatever: the very long spiel of a succinct answer.
Wendell,
To get the answer you want, do thisâŠ
Buy $2.5 million of Goldman Sachs stock, this will make you a board member, ask Axel @ MarklinâŠ
At this point Iâm going to agree with JJ on how things will pan out. I also agree with Jerry, the silence is the best indicator that things are progressing. Failure would bring an immediate response from somewhere.
Use common sense. LGB was down for some timeâŠeverything was at a grinding halt. There is NO WAY Marklin could get the whole world up and running at one time. Most of the world plays with European style trainsâŠthus those markets would be the easiest to get up and running first. The US does notâŠthus our stumbling block. Given due time we will have LGB back on the shelves. And my prediction is by the end of the year we will know.
Warren Mumpower said:
At this point I'm going to agree with JJ on how things will pan out. I also agree with Jerry, the silence is the best indicator that things are progressing. Failure would bring an immediate response from somewhere.Use common sense. LGB was down for some timeâŠeverything was at a grinding halt. There is NO WAY Marklin could get the whole world up and running at one time. Most of the world plays with European style trainsâŠthus those markets would be the easiest to get up and running first. The US does notâŠthus our stumbling block. Given due time we will have LGB back on the shelves. And my prediction is by the end of the year we will know.
Warren,
If you watched a few of the European insolvencies - not necessarily or exclusively in the MRR sector - getting untangled, then you would know that the NA situation is highly unusual and thatâs putting it mildly.
Possible reasons for delays will be listed in a different thread. :0
HJ, the soap opra is over and I think most of us are burned out on speculative reruns.
Warren Mumpower said:Warren, It ain't over till its over. The fat lady has yet to sing.
Meanwhile, I think that I will just keep working on my track.
I rather believe that any arrangement with LGBoA will be transitional.
Marklin donât need LGBoA as an operation employing people.
LGBoA might own some intellectual property that Marklin might want (in the future) but the point is they donât âneedâ it as badly as LGBoA needs product. If the spotted deer store starts showing a full range of LGB products again then Iâll believe an arrangement has been reached that allows LGBoA to sell product (which might not include distribution of product). Still some way to go before the dust settles.
Les
My vote is #6 and #7.
Would there be this much piffle if it was Aristo that was bankrupt and TU?
TOG
TOG,
That all depends.
But in essence it doesnât matter, what matters is âGood product at a reasonable price available within a reasonable time.â
Just found out today that the KISS engines (Ge 4/4â and Ge 6/6") will be delayed because the order volume is much larger than anticipated. Instead of Nov/Dec it probably will be Mar - Iâm just guessing, but it would be a nice birthday present.
BTW Those who sweat it better stock up on deodorant.
John Bouck said:
Would there be this much piffle if it was Aristo that was bankrupt and TU?TOG
John: I canât imagine that there would be near as much bleating. Most folks who are in the model RR hobby realize: 1) Itâs a hobby. A very good and interesting one, but still just a hobby; 2) There are numerous sources for trains and materials. Some good, some perhaps not so good, but truly lots of choices.
Many of the LGB toy train collectors distinguish themselves as a breed apart! If it doesnât say âLGBâ it just doesnât exist!
Happy RRing,
Jerry
HJ,
Whatâs the status on the KISS Mikado?
Any rumors?
TOG
John Bouck said:Which scale? O scale as in SNCF 141R?
HJ, What's the status on the KISS Mikado? Any rumors? TOG
No,
the 1.22.5 K-36
Did someone say 1.22.5 K ? Gratutitous pic time⊠Sorry cant help it⊠too good to pass up⊠even if it isnt a 36
Sweet!
Rod-
Thanks for the photo!
I have yet to see one.
Might you know:
1- Does the KISS loco, compared to the new Bâmann K-27, require the same minimum radius?
2- Any idea as to cost?
3- Any opinion, considering 1:22 the locoâs actual size, and most ownerâs mix of car sizes, that it will not be dwarfed and out of place?
4- Who carries this animal?
Thanks,
Wendell
Wendell,
Check thisat KISS. They mention R2 and 1500mm in the same breath. Well 1500mm is approx 5ft; R2 is 2.5ft
Hans-Joerg Mueller said:
Wendell,Check thisat KISS. They mention R2 and 1500mm in the same breath. Well 1500mm is approx 5ft; R2 is 2.5ft
I suspect they mean R2 radius and 1500mm diameter, both are about the same but its just not very well clarified. R2??? a K36??? âŠthat Bachmann Beasty wont be able to touch anything under 8â diameter. To bad its over $3K US
HJ, Whatâs this mean? Taken from the website. Sie haben VorschlĂ€ge, Kritik oder Anregungen zu diesem Produkt? Hier können Sie Ihr Anliegen eintragen oder eine E-Mail schicken an: [email protected] Hinweis: E-Mails an diese Adresse werden NICHT beantwortet, da sie nur fĂÂŒr VerbesserungsvorschlĂ€ge zum Produkt genutzt wird. Wenn Sie Fragen haben, verwenden Sie bitte weiterhin die bestehende E-Mailadresse [email protected]. Vielen Dank! Vorbildgerechte Beleuchtung fĂÂŒr Fahrtrichtung FĂÂŒhrerstandsbeleuchtung Radreifen aus Edelstahl, ringisoliert Federpuffer Achsen gefedert Mindestradius R2 (1500mm) Gewicht ca. 7 kg Achsen kugelgelagert Antrieb kugelgelagert AusgerĂÂŒstet mit Digitalund Sounddekoder
Have suggestions, criticism or suggestions to this product? Here you can register your request or send a E-Mail on: [email protected] Note: E-Mails to this address are not answered, since they are used only for improvement suggestions to the product.
If you have questions, please use the existing E-Mail address info@kiss modellbahnen.de. Thank you!
directional lighting
cab lighting
wheel tires made of high-grade steel, insulated
sprung buffer
axles fitted with springs
minimum radius R2 (1500mm)
weight approx⊠7 kg
axles run in ball bearings
drive runs in ball bearings
equipped with Digital Sound decoder
Jack
