There’s been chatter around here of winter projects. So I thought I would I would share one of my winter projects. The other being some skeleton log cars. (Thanks to a member here who is sending me some plans in 1:20.3) It will be a 5’ radius curved trestle with the option of a short straight section at either end. This trestle will be installed at the lower end of the RR to greatly reduce the amount of fill required. First started milling up 1st growth red cedar, the 12 x 12 posts and sills and the 8 x 18 stringers. Still have to do ties, guard beams, girts and sway braces.
I then made a template out of particle board to build on.
Here you can see the option of straight track at the end.
Hopefully it will be ready to install in the spring. It will be worked on slowly over the winter months as time permits. BTW it will be loosely based on Rio Grande trestle work.
