The other day, while contemplating running my trains counter-clockwise, rather than the usual clockwise direction, I realized, having visited several layouts and seen a number of displays, that all I had seen always ran clockwise.
Questions:
1] Which direction do you run?
Ans. - Up until now, clockwise.
2] Is there a particular reason for running [cw, c-cw] that direction?
Ans. - Before the recent double-tracking project, which installed concrete and ladder roadbeds, the uphill grades for the locos would have been much more severe going C-CW than going CW.
3] If you also run other scales, what direction do they run?
Ans. - I also have HO and ON30, both of which run CW. My grandkids “G,” and “O” layouts both run CW.
4] If you run a Christmas [Holiday] Train, what direction does it run?
Ans. - CW.
5] What would make you consider changing direction of “usual” operation?
Ans. - Operating C-CW in one area is easier to change from the outer loop to the inner loop [every 180degrees]. Going CW, the train has to go around 360 degrees to change loops [outer to inner].
JimC.
