What I’ve been working on…albiet very slowely, along with the Nww Blight pooper Mik sent me. Probabaly the last model using Aristos drive bricks under the current fiscal restraints…
This is me using up some of those left over peices from all them other Mack bashes. It started as simply a double cab glued together with two radiators minus the hoods, it was going to go over a battery powered chassis, but after I got it together and painted I added the extra hood units and really liked the way it turned out so I built up the chassis, which is a thick sheet styrene w/ 1/4" basswood stiffeners, and 3/16 basswood stock built up end beams. Drive bricks will be Aristo centercab bricks, likely taken from another less used model, as I’m trying to refocus on my most primary needs, I will likely be boxing and storing my larger items like the Superliner cars until I can focus on building the outdoor line, so I will take the bricks from the F40ph and use them on this model as this model is much more appropraite to the scale of my indoor line. I will replace the F40 bricks somewhere down the line when I can.
so its off to beddy-bye with them for now until I can lay some 8’ diameters out back in the side yard.
