Thanks, Pete. Sometimes we just need a little nudging to get started. As I mentioned in the other thread, I have settled on a track plan for the first phase (of many). It will include about 60 feet of benchwork. The layout will be elevated not unlike Ken’s. One difference is I plan to maintain a minimum height of 36" but there will be places that the track will be 6-7 feet on one side of the benchwork and 3’ on the other due to the topography of the layout area. The towns will have benchwork that is 6’ wide and accessible from both sides so the longest reach is 3’ which I can handle. Not all benchwork will be that wide, some areas will be 2’ wide. The first phase will be the town of Bear’s Den. It will have several rail served customers, engine servicing facilities and engine house. Future phases will expand from Bear’s Den to logging camps and mining areas. Bear’s Den is the home of Brown Dog Timber & Lumber.
I’m considering building the benchwork like modules. Construct a supporting structure in the layout area and then build an 8-10 foot module that will sit on the base structure. This will allow me to build the track work, scenery and topography in the shop and once completed pick it up with the tractor and take it to the layout. This would also allow for future modifications, repairs, etc to be done in the shop. Currently crunching numbers to determine approximate weight so I know how long I can build each module. The layout will consist of a series of connected modules to create a focal point like Bear’s den and then narrower modules or maybe trestles or something similar connecting to another set of modules that could be at a different elevation. Each set of modules will be relatively flat with only minor grade changes within that set. It sounds complicated but its really quite simple or at least it is in my head. Just imagine a number of towns at various locations, each built upon a series of modules 50-80 feet long combined (i.e. 5 to 8 ten foot modules) and then connected with narrow benchwork or trestles/bridges. The difficult part is designing the connecting track to maintain manageable grades.
Still a long way to go, but the first phase is straight forward because it will be relatively flat, no major grade changes, just something to get trains running. I’m finishing up drawing the trackplan now and will post when it is complete but it will be a few days yet as I am getting ready for the Mik Challenge.
More to come.
