I am building a watermill / woodprocessing factory, it is a large structure designed to be on a sloping grounds sloping down to a river. This building is constructed of sheet metal, The waterwheel is made of steel, 10’’ diameter and 5 ‘’ wide. It turns very easily being it is supported on two pillow block bearings. It weighs 13.5 pounds which will allow it to turn very slowly which will look very prototypical. The structure has 13 different roof lines and leveles to represent many different add-ons,
This structure will represent a wood processing factory, have not decided on what type yet.
The water tank on top of structure
This picture shows the waterwheel plus I have started covering the walls with magic sculpt
Close-up of the wheel will show the rivet plates
Thanks Dennis
