This morning I wanted to even out those roads coming off the mountain, now that I’ve decided to make those flats have diagonal bases (with each building going up a step). The saw-tooth look looks dumb. But my conduit stubs were already getting buried, and need extending for sure if the road mortar was going to be even thicker there.
So I took some 7/16" styrene tube, shoved it into the semi-buried conduit. Then I put a short piece of conduit the styrene. After mortaring all around, it’ll be like a single piece of conduit. Later on, I’ll remove the styrene tube and trim the conduit extension close to the newly raised ground level.
After that, I was able to build up and even out these roads. Then I kept going through the main city area.
Looks like another day of mortar work is needed, then a couple days of cleanup. Then staining, track replacement, and finally back to the installation of the 1st four flats.
Thanks for watching,
===:>Cliffy
