Well I’ve alluded to it a couple of times and those that have been to the KVRwy over the last couple of years have seen the mockups, but I’m thinking its far enough along to start showing some of the work being done at Valley Power on the Southern Branch of the Kaskaskia Valley Railway. This is an industry in the basement that allows operations with, or independent of, the outside portion of the railroad.
The objective is to create a large overpowering industry that seems to be much more than what you can see, and actually only model the rail transfer portion. My idea was to try to create a conglomerate of buildings that all the walls of brick and concrete block have been painted the same to give it a uniform color and show its growth and additions through many years and eras of construction. Valley Power is a coal fired power plant that is a receiver of the coal that is mined on the KVRwy and processed at the Owl’s Bend Chance Coal Processing Plant.
Currently there is just the lead off the switch back headed to “Shadow Box” and the trackage going into the boiler house. Supplies will be delivered here, along with heavy machinery going in and out of the power plant.
You can see the inside of the supply dock with a fork lift carrying a large valve or pressure release vent.
And a close up of the signage of the roll up door and surrounding area.
A turnout will be installed at about the front of the engine where the embankment falls away.
It will be to the coal dump and should have a turnout off of the dump trestle for the hauling off of the ashes. This will be in the brown (that’s actually a color of paint called coal) area.
A lot of the work, so far, was working out away from the wall, so I didn’t destroy the rest of the work while building the structure.
The valve, roof blower motors and ladders with cages came from some supplies AndyC provided. I think they really add to the industrial look of the area. There is a long way to go on this project, but its been under construction for 2 years and progressed from plywood to concrete block buildings since the middle of December, 2008. The brick work and division stone is from Precision Products and the concrete block is carved with a hot knife on 1/4 inch styrofoam.
