Greg , rubbish .
Moisture does get into pipes/tubes . Don’t be silly .
I even tried (in desperation) my spray compressor fitted with two driers in tandem which I find essential when paint spraying . Moisture gets in , not so much , but you cannot completely stop it without using a pressure dessicant which are expensive , bulky and can only absorb a limited amount of moisture .
Your comment about the lines self purging does not hold up to scrutiny----the air passes along the pipe in spurts , so a lump of air goes from reservoir to switch in jumps . This air therefore spends some time in the pipe . So it takes a while to purge , as you put it .
After use , my compressor gets a blow down to remove moisture ; thus every time it starts up , it brings in fresh moist air .
Also , after use , I disconnect the pipe at the airbrush end and blow the moisture out of the pipe , it is pretty obvious from the amount of emulsified muck that comes out that moisture traps only trap so much .
If your supposition is correct (it isn’t) sell your system to aircraft fuel system engineers , they would sell their souls for a means of stopping water in fuel and hydraulic systems.
We also had a heck of a problem keeping waveguides dry , and in the finish had to accept that the waveguides and equipment had to be pressurised with dry nitrogen , which is expensive . So much so that although the RAF have nitrogen producing plant , the dry nitrogen had to come from the manufacturer as they had the means for making dry nitrogen for use in medical stuff .
The production of visible moisture happens with temperature change----survival equipment relies on this fact to provide water for downed aircrew . A device to collect overnight moisture caused by temperature changes is /was provided in survival packs .
Finally , my “moisture free” self bleeding pipes froze up in overnight frost .
So perhaps you can now explain your insulting remark about the matter of moisture in pipes being silly . Explain exactly how it can be completely stopped . Or make yourself look even sillier .
Mike
