Got started on my 844 build project. Using old Pacific parts. Got some Boxpox wheel castings from Bob Thon, they are about the same size as the Pacific’s, once turned down. Using an old Pacific drive that had good gears and the pins, so easy to get the wheels lined up and will stay in place. The rear driver and 3d driver get power, other two are along for the ride.
Boiler was pieced together and covered with thin layers of plastic, after sanding off the cast in pipes/etc.
Front piece is from Bob Thon as is the large dome.
Wheel castings need the center hole drilled out larger and a groove cut on the back to slip over the axle pins.
