UP had a streamlined Pacific they used with the 49er out of Omaha to Cheyenne in the late 30’s. Sort of ugly, but appealed to me for some reason. I picked up a used Pacific at Marty’s and used some plastic plumbing pipe and elbows to get an approximation of it’s shape.
The center axle had Boxpox wheels. I got some castings from Bob Thon and turned down the flanges(he has the tread turned is all). I modified the Pacific gear to look more like what the UP had.
I used brass cotter pins from the hardware store for the handrails stanchions. UP did not use diamondplate, but had metal with holes punched in it to drain off water. I used metal duct tape and ran a pounce wheel over it to simulate that.
The side fairings are just clipped on so I could do the front edges with the half-round Evergreen. I will not glue them on till I get the paint done. The cab/boiler come off in one piece(screwed on) so I can paint it off the chassis also. The tender is next.
I like it!
