I’d noticed the dimples at joints, great idea. So doing the same as filler makes sense.
Once you get your method down, I’d love to see some shots of the filling / cutting / sanding.
This seems to work nicely. Let’s start with this slot and tab.
First step is to weld it shut.
The build up the area with filament. Make sure you melt the base material as well, to get a good bond.
Continue until you have a good pile.
Trim close to flush with an X-Acto, and then with various files, smooth it down. You may find voids that you have to go back and refill. This is just like welding!
Eventually you get it nice and clean. Next I would coat in primer and see how bad it looks. Might need some putty to smooth things out.
Excellent, thanks Bob. Looks like it really works.
Do you know of a putty that will adhere well to PLA?
Squadron white seems to stick to PLA pretty well. We’ll see how it does with PETG once I start printing these in that.
I’ve wondered if anyone has used a filament pen for this sort of gluing. It seems like the ideal way to squeeze just the right amount of plastic into cracks.
First test assembly of the 25 footer. Came out pretty nice.
And for comparison with the 22 and 28 footer
Bob,s manufacturing company might be a good siding
Really nice work.
And you can use archbar trucks! Vulcans are tough to find.
I was pretty confused on what trucks were found on what cars early on in this thread. That’s primarily because two of the Bachmann 2-Bays that I bought from you are weathered and numbered 810 and 838 and were supplied with arch bar trucks. When I called you on that, you explained that they were models of the earlier 2-Bay cars. What I didn’t get was that the Bachman cars were 22’ and the PSC cars were 25’. So my 810 and 838 are really just suggestions of those cars. That’s OK because I have an EBT based wood box car that is too short as well
Shortness is a theme of yours
The Bachmanns are models of the 4 “Rock” hoppers that were built much later than the PSC cars. By the time the 22’ cars were built, all the PSC 25’ cars had been converted to 3-bay 28’ cars.
I read somewhere that the PSC hoppers were unstable - too much coal too high?
