I just measured the specs for the “bigger” mogul Kevin and I will be making. This will likely be the largest locomotive will run. It is right at 5" wide. I measured the mogul I just got done building (well the drawing I measured off of that David Fletcher drew) and it is 4" wide. These are both 1:20.3 locos. I also believe that my NG freight cars are 4.5" wide I thought they were four but I know they are wider than the locomotive by a little bit.
So worst case scenario for the equipment I plan to run is that they will be 5" wide which at 6" C to C will give me an inch. And this will only be in the yard.
