OK So my head is starting to spin and there are several threads I am involved in that I am trying to put all the information together on. Turn out configuration verses yard layout and maximizing space is the order of the day.
Here is the basic yard configuration I am playing with:
This basic idea is thanks to Sean helping me realize the most for my space. Now in my other conversations I think I am perfectly comfortable with #4 standard turnouts for this yard and that is what is represented in the drawing. It gives me 9 tangent tracks in my given space with roughly 4" center to center on the tracks. I tried using a #2 wye as the first split in this configuration and all I could get was 8 tangent tracks using #4 turnouts. It did yield wider track separation though. I then decided to try a last ditch effort and simulated a 3 way turnout as the first split by using a #4 regular turnout for one half of the yard and then mirrored it and overlayed the now flipped switch on the original lining up the straight tracks effectively creating a 3 way. Not a staggered style but a true 3 way with a single set of point rails. This yielded a more uniform configuration than above by making the top four tracks look like the bottom four tracks which lengthened them. All in all this gave the longest legs and 9 tracks with 4" separation center to center. I could extend the separation of the tracks some by adding small section of straights between turnouts if that were and issue.
I am liking putting s 3 way in place. So if I were to make a three way am I to assume that in its construction it would be basically a right and left standard turnout superimposed on one another? Would the point rails be the same as a standard #4 and would use two #4 frogs? or is there something I am missing?
Does anyone have a template for a #4 3 way turnout? For that matter does anyone have a template for a regular standard #4 turnout? How about a #6? and while we are on the subject what about a #2 Wye so that I can build my wye section? I am planning to use llagas #4 and #6 frogs. For the wye I would have to make my own frog.
