Ok So I am no where near ready to start laying track but I am dreaming about a layout. The wife has deeded me a 50 X 12 foot area in the side yard. I wont bore you with all the details but it will have two separate loops one over the other with one crossing and one area to switch between loops to make one long double loop. I am hoping to make the ladder using 2 1/2 X 3/4 wide vinyl trim. I wanted to stay at or below 1.5% grade. I accomplished that in my design and came up with the crossing point being 12 1/2" separation from top of rail to top of rail. Figuring if I had to leave the 2 1/2 inch ladder material in place it would give me a 10" clearance. I model in F scale with and the loco I am building now will be less than 8" tall. My corner radius are all 4’plus (8’ dia.).
I probably should mention that I am not planning on having this elevated to far off the ground as I have plans to have paths cross it by making small steps/bridges to walk over the track (tunnels for the train). Where the crossing occurs, the lower track will be at ground level with the bottom of the vinyl on the ground and crushed rock brought up to the top of the Vinyl. Then the ladder will rise to the max height of 12 1/2".
Here are a few questions. Is 10" of clearance going to be enough to allow others to play? No giants will be able to run but any smaller equipment should make it with the corners and clearance, right? Oh I doubt it matters but there will be no track power, sorry none battery guys.
Now for the main questions. How does one construct trestles in the ladder system? I have plans for one that I would like to be about 3’ long for the crossing. It will cross a canyon. Do you break the ladder and then use the trestle to support the track? If so what do you use for a base for the trestle to keep it from heaving? My thoughts would be to dig two holes with a post hole digger down 30" (that’s supposedly frost line though I have never seen it that deep and I do excavating work for a living) and pour two concrete pillars to ground level with some bent over rebar sticking up about an inch or so. Then pour on top of that (it would be one monolithic pour but for explanation purposes) a 2 1/2" thick (thickness of the vinyl) slab wide enough to catch the bottom of the bents and 3’ long. This would be the base I could work off of for the trestle. I would also pour in two bolts on each side that the ladder would anchor too. This would be the starting point for the whole system. Does this sound reasonable? Am I trying to reinvent the wheel? Overkill? Not enough? would be easy to do and seems like a rock solid starting point.
Suggestions and links appreciated.
Devon
