I have decided upon building a Well/Pump house for my windmill that I had started almost 2 yrs ago and never completed. I have the tower built and started the fan. So now I need to construct a building to go along with this. This structure will go along with my water tower I built two yrs ago. So let the fun begin… Travis
This should be a very interesting build. Good luck with it, Travis!
I look forward to seeing your build. It’s something I need to add to my windmill.
Thanks Fellas…
Well I cant figure out how to have the photos show up here. So here is the links from photobucket… I am building a windmill pump house… I am use pieces of scrap lamanent flooring 10 mm thick for the four walls,1/4 in. plywood for the roof and odds and end scrap pieces for the window and the door from Dave Taylor’s door manufacturing facilities. At the peak of the roof I cut a dowel rod on the table saw to cap it off, not sure if it will be shingles or tin roof yet. The windmill tower I had built around a year and a half ago and never finished so i decided to build this to go along with my water tower.
http://i1194.photobucket.com/albums/aa375/General1861/100_8216_zps0054799b.jpg
This pic shows My first attempt at the building frame of 1/4 birch plywood. It was not to my liking, hence the new frame sitting on the right side of it.
http://i1194.photobucket.com/albums/aa375/General1861/100_8217_zpsbeeeb508.jpg
http://i1194.photobucket.com/albums/aa375/General1861/100_8218_zps18458311.jpg
http://i1194.photobucket.com/albums/aa375/General1861/100_8219_zpsf12f059a.jpg
http://i1194.photobucket.com/albums/aa375/General1861/100_8220_zps0abe53ef.jpg
http://i1194.photobucket.com/albums/aa375/General1861/100_8221_zpsf429692a.jpg
http://i1194.photobucket.com/albums/aa375/General1861/100_8222_zpsb51b8ce8.jpg
last photo is a trial fit before roof goes on. So far I have not spent any of the allotted thirty dollar budget… Travis
I think I got’em all…
Looking good Travis
Very nice build. Good work on the tower.
Tom
Thanks Tom, The tower was already built from a year ago, so if this would disqualify my project from the contest thats ok . It has be laying around like you see in the photo,
Here are some more progress photos… window frame built
http://i1194.photobucket.com/albums/aa375/General1861/100_8228_zpsb3be0c69.jpg
Window and door fitted http://i1194.photobucket.com/albums/aa375/General1861/100_8231_zpsb1a393a5.jpg
Door and window temporarily installed and A side of building sided… Need to cut more strip wood as I ran out… More to come… Travis
http://i1194.photobucket.com/albums/aa375/General1861/100_8229_zps3eaed471.jpg
Kent Brunt, Thank you! for posting my pics. i have tried to get them posted witout the link, but I am overlooking something here. When I try the insert option on the scren it just gives me a blank, just text when I post… Appreciate the help… Travis
Your welcome. I imagine your problem is with your browser then. You’ll get the hang of it eventually.
oops, forgot one…
Great addition to the well.i have a place on my layout picked out where mine will go!
decided to go with a “tar paper roof” 150 grit dry sandpaper with titebond III glue.
http://i1194.photobucket.com/albums/aa375/General1861/100_8237_zpsda6c5446.jpg
Other side being fitted and cut…
http://i1194.photobucket.com/albums/aa375/General1861/100_8238_zps09693bd1.jpg
well well hopefully i have this figured out posting pics
