Hmmm .
You have me thinking David.
Before making drastic cuts I think I will try adding a bit of weight to the trucks and then look into increasing the contact points under the bridge section. The lifting arm ends sit directly on the bridge whereas the bridge sits on wide fender washers on the pivot points. I think the washers that raise the bridge off the trucks give too much space for tipping when the load goes off center.
The Schnabel made it through this curve when it just had the connecting piece in the photo above but when the deck was added the overhang was extended.
I just might have to setup something to allow the load to pivot on its own.
