Back in the spring, my Ten-Wheeler suffered a fall from the highest elevated point on my railroad.
This was basically a 1:20 ten-wheeler built on a BBT chassis back in 2006. It started as a Bachmann Anniversary, but about the only thing left from the Annie is the bell.
It has always been my favorite, but it sure didnāt look good after the wreck. I decided to start with the tender. The more I looked at the existing tender, it soon became clear that Iād just have to start from scratch. I took what I had learned from my Mikado project and built a new one from styrene. I was able to use the trucks, back steps, brackets, and water valves from the old tender.
There was no good way to repair the wooden cab. Anyway, I decided it was time to modernize the locomotive and give it a steel cab. I used .040 styrene to form the inner layer.
Next, I cut some .020" styrene and embossed some rivets. This was applied over the inner layer using contact cement.
The roof is not as smooth as Iād like, but itās just the inner layer. It was SO nice yesterday, I took it outside to finish embossing the rivets on the roof.
This was glued to the first layer and clamped in place.
Iām attempting to finish it in time for the Invasion, but itās sure getting close. The nice weather makes it hard to work in the basement shop.
